Front band
gremlin
268Darts
Houston
I opened up my trans to see if I needed to order a 4 pinion front planet gears and noticed the front band was solid...is that the factory band? It looked kinda redisn. The rear seal has been replaced so I'm thinking this trans has been gone through before.
I'll get a pick tomarrow. I'm thinking about sticking it back in there. It has 4 grooves and looks great.
Solid bands are out there, and as stated above if it looks good use it.
The solid front band is considered a performance part, so you may be right about it being built before.
My front band
All the older trans. had solid bands. I don't remember when they started using flex bands but I'm sure it wasn't until the 70's.
