[SOLD] FRONT DISC BRAKE ASSEMBLY 5X4.5
Cornernfool
Arizona
Rating - 0%
0   0   0
DODGE/PLYMOUTH A BODY DISC BRAKES REMOVED FROM 1975 PLYMOUTH VALIANT. VENTED/SLOTTED ROTORS, CALIPERS, BRACKETS, SPINDLES, LARGE BALL JOINT UPPER A ARMS, BRAKE HOSES, HARDWARE. $500.00 PLUS SHIPPING. EVERYTHING YOU NEED MINUS BEARINGS, SPINDLE NUTS, BRAKE PAD HARDWARE. I CAN SHIP THIS ON YOUR DIME. I'M GUESSING ANYWHERE USPS FLAT RATE LARGE BOX (4) FOR $85-90.
DODGE/PLYMOUTH A BODY DISC BRAKES REMOVED FROM 1975 PLYMOUTH VALIANT. VENTED/SLOTTED ROTORS, CALIPERS, BRACKETS, SPINDLES, LARGE BALL JOINT UPPER A ARMS, BRAKE HOSES, HARDWARE. EVERYTHING YOU NEED MINUS BEARINGS, SPINDLE NUTS, BRAKE PAD HARDWARE. I CAN SHIP THIS ON YOUR DIME. I'M GUESSING ANYWHERE USPS FLAT RATE LARGE BOX (4) FOR $85-90.
Price?
I think you show the lower ball joint hardware but not the caliper mounting bolts.
The lower ball joint bolts are there, along with the caliper bracket mounting bolts and dust shield bolts. What is missing are bearings, spindle nuts and washer, and caliper to bracket hold down bolts and shims. Did I miss something?
That's what I was referring to as "mounting hardware".
What I am not sure about is if the original drum LCAs can be used, OR do I need a later model version that came with disc brakes??
I have been told the uppers are different, but the lowers are the same. I went with tubular uppers, dropped spindles, 12" rotors with the pin style calipers.
It's the lower ball joint/ steering arm that is different from drum brakes.
You are right, I did not see them the first time GLWS
