Front disc conversion - stock prop valve or adjustable?
RGAZ
Diehard
Greenwood, SC
73 duster front disc conversion. Forgot to get the prop valve and clearly need one. Rear was swapped to 8-3/4 from b-body so do I use the stock Duster prop valve I can get from Classic or Dr Diff or should I get an adjustable? Is there a better prop valve option maybe a B-body?
Thoughts?
RGAZ
10" from a 70 Roadrunner.
RGAZ
With a mix-n-match setup, I would recommend the adjustable. Who knows what size the pistons are on the calipers and if they match up well with the master cylinder or wheel cylinders for that matter....
I believe you want the valve AFTER (to the rear of) the dist block so as to keep the differential valve centered
Did you put it between the MC and the Dist block or after the Dist block
You put it after the distro in the main line to the rear brakes
Also...
If your stock distro has a prop valve built in you will either need to use the built in valve or replace the distro with a straight distro no prop valve and add the external in the brake line to the rear
I just checked rock auto.
The rear drum on 73 dart 10x2.5 used a 15/16 wheel cyl
Guess what also used a 10x2.5 and a 15/16 wheel cyl.... 70 roadrunner!
I would go with the factory all in one prop valve.
73 dart
70 roadrunner
Stock car was 4 wheel drum and the Dist block looks like just a dist block with no prop valve in it (no side entry port) and with my recent test drive (with front disc) it was rear brake heavy (like badly) so I am sure it has no proportioning ability at all. But yes, I get it.
Did you put it between the MC and the Dist block or after the Dist block?
I eliminated the OEM proportioning block. I believe some applications use Residual pressure valve before the rear drums. Have one, but haven't put it in yet as the brakes are working well.
I know I'm going to get beat up on this one, but I converted a 68 Dart to 73 front discs and left the valve alone. It worked pretty dam good. I did replace it eventually once I did a v8 conversion to it. Remember it's your life and brakes so I was just saying.
I went with the wilwood.. i can't tell any difference from full open to full closed though (closed is something like 60%, not 0%..)
Mounted it off one of the MC studs... quick flat metal bracket
This is what I was going to do, but the group says mount it AFTER the Dist block which would put it way down on the rail. Could the Dist block be messing with your setup which limits your adjustability? I thought it was just passages to split the pressure.
Me too. Put '73 Dart setup on the '72 Duster with a B-Body 8.75" rear axle with 10" brakes.
No.. and mounting it after the dist block should make no difference at all (as far as i know).. it's a straight line from the MC to the rear brakes.. I could be wrong but unless someone explains why it matters without just saying do it that way.. meh.. I have seen most prop valves before the block
I'd prefer it after down low so you don't see it. Once adjusted you won't touch it again.
It also has the brake warning switch in it.
There is a piston in it that will move to one side and short out the switch should the front or rear system fail.
This is the 67 distro. (No prop valve)
If the mc applies 100 psi to the front and 100 psi to the rear the piston assy stays in the center
If you put a prop valve before the rear inlet then when the master applies 100 psi to the front and 50 psi to the rear the piston assy moves shorting the valve
If the prop valve is after the distro the distro acts like the first example.
(These dates are approximate)
The factory 73 up distro has a prop valve built in.
The 72 down has a separate prop valve down stream on the inside frame rail.
Depends on what you have.. if it was like mine, old drum/drum it's literally just a block with ports in it
