Front end Geometry????
DesertRat
Leading edge boomer
Moses Lake, Washington
Can anyone suggest numbers for the allignment shop on my stock 67 notch with 14" radial tires & power steering? I know they should be different from the old bias ply days.
TIA, Rat
So do I need to change the upper control arms to hit the
2.25 deg positive caster or just get as close as I can with
the stock gear?
Rat
that sounds pretty good.. Just get as close as you can and make sure they are even. otherwise it will wonder.
