front knuckle and control arm
nico06
Member
NICE France
i have a 1968 barracuda with front disc but 4" somebody offer me the disc and knuckle and control arm of 1968 cuda 4.5". does it mount on my barracuda ? if not how can i do to get 4.5"bolt pattern on my car ?
THANKS YOU
or where can i get exploded view of a cuda 68 front disc and train with details and a barracuda 68 !
thanks again
A bodies from 1963-1976 all had the same basic design control arm. The ball joint shaft diameter did change from the 9" to 10" drum/disc set up. 1973 was the change over to 4.5" bolt circle and the single piston floating caliper design. Prior to this, the four piston opposed caliper design and the 4" bolt circle were installed on all A bodies regardless if it is a drum or disc system. There are many control arms still floating around, just post for some and thousands will appear! Including the aftermarket ones!!!
