Front shocks
moparstud440
Keymar, MD
For those of you with a ladder bar rear suspension and stock front end (not tube chassis cars). What/who's front shocks are you using? I'm currently using the Comp Eng 3 way shock set on 90/10, but looking to upgrade to better shocks over the winter.
I have QA1 single adjustables on my Dart, but Viking shocks (Original founder of QA1 I believe) are also available in single & double adjustables. I had them fab up some shocks for my Aspen, but I haven't run it enough to really get it dialed in. (SS springs on the rear.)
I run QA1 R’s on the front. Single adjustable, but they really adjust extension and only change compression a touch. Works for me. Viking is the name I hear, but pricey.
Viking makes ONLY double adjustable shocks, as the realize a single adjustable shock leaves something on the table and a 90/10 shock is a museum piece.
Get the Viking shock, and learn to tune with them. You'll wonder why you didn't do it sooner.
And with a ladder bar, you should buy some for the rear as well, if you don't have a DA shock back there already.
I have QA1 doubles in the rear.
Just put a new set of CE 3way on the front end of the 71 Dart....
