Front spring hanger and u-bolt plate questions
Brad54
I'm ditching the stock rear in my '73 Duster, in favor of a yet-to-be acquired 8 3/4.
I'm guessing this will also require new u-bolt plates? I've got a friend that bought the rear for his '67 Barracuda, and now he's thinking he'll need those plates.
Will I need 8 3/4-specific u-bolt plates?
Also, what are you guys using for front spring hangers? I've seen a couple that are beefier, and have an additional mounting hole to lower the rear a little. Anyone have experience with those? Worth it, or just keep the stockers?
I'm going to put in torque boxes and USCar Tool subframe connectors to stiffen up the suspension a bit. Anyone have any thoughts on spring hangers?
-Brad
try and see if the ones on his hotrod fit the new rear. you can weld a piece on the front hanger and drill holes to raise the spring eye or you can install them upside down by drilling new holes.
If you are replacing a 7&1/4 you will need the shock plates and new U bolts.
The 8&3/4 axle tubes are a larger diameter.
