Front wiring harness route around the radiator support?
hcallaway
Richmond VA
Is this the general route?
That makes sense!!! LOL I could not find shots that I could see exactly how they routed. Do they feed thru the big odd shaped hole on the driver side?
You can see from the lack of paint fade, missing the two ground wires that use to go to that screw
Yep... Pretty cool!
I was in the process of replacing the drivers side front fender, so lots of things were disconnected. I also found out that with those 2 grounds disconnected the turn signals did not work.
