Hey all, I have here a set of interior front and rear door panels for sale as removed from a 1966 Plymouth Barracuda. They are white in color and in pretty decent shape. The fronts are actually better than the backs. One of the backs has a hole through the panel from a broken window actuating rod that poked through from the back. The other rear is a little puckered at the bottom, but still solid enough to use. The fronts are in decent shape, a little marked up but could probably be cleaned, and there is a small hole right around the edge on the drivers panel where the panel was rubbing on the sill plate. All in all, a decent set for your missing or damaged units in daliy driven and fun field cars, but not clean enough for show cars. $75.00 and you pay the shipping. Thanks for your interest all, Geof
