Chas,
Some white scoops will definatley stand out on your car. Your car looks great BTW.
Yes I do still have some templates left. I like you were also scared about drilling into a perfectly good hood. But I have found out that with the template it does make it easy and as long as you take your time and double check your marks, their should be no problems. I have sold over a dozen of these and haven't heard of any problems just great reviews about the install being easy and fast. I have a step by step process that comes with each template and again this is only a guide but it seem to be working. One thing I tell everybody about the stud holes is that they were very big from the factory. They are 1/2" & 3/8". The studs on the scoops are under a 1/4" so their is room for a little error. Also I show how to make sure that your studs match up to my template and if not how to fix it. I have only seen one hood scoop from an aftermarket or either home made that only had 4 studs. But most match right up.
About the stud kits Year One sells them and I see them every once in a while on Ebay. We have a store located here locally that carries all kinds of bolts studs ect for things like this. I have used them many times for other car items like clips, terminals and other misc. stuff. Check you yellow pages for something that handles fasteners or just hardware. Take your scoop down and find a stud that will fit. The stud only has to protrude about an 1/2" out the bottom.
If you should have any other questions PM me with your number and I will call you.
TAZZ
