mopar56
well we finally got my sons Duster back on the road after working on it all winter and after it being off the road for who knows how many years, as usual there are bugs to work out but right now most importantly the gauges don't work, the fuel gauge and temp gauge both sit at the bottom and never move, we grounded out both senders and neither one moves, the fuel sender looked perfect when we had the tank out and it has been replaced before in its life, the wire harness for the temp sender is still wrapped and looks ok, I didn't try grounding the oil sender yet to see if the oil light comes on but I will and suspect it wont, we had the dash cluster out to change some bulbs and bypass the ammeter in the winter and although I wasn't looking for problems the printed circuit looked good visually, I seem to remember a voltage limiter on the back of the cluster that were troublesome could this be our problem? we are probably just going to install some aftermarket gauges for reliability but it would be nice to have the ones on the dash work to, thanks.
