smythge said:I can see the filter and you said it vents through the floor with a grommet, is the other end of the hose just open and basically poked through the grommet and venting throught the the underside of the car?
74360duster said:Summit Sells A Holley Blue Electric F/p,holley F/p Regulator,20 Ft. Of Braided Hose And All The -6an Fittings You Need For $230.i Installed This On My Small Block Duster And It On Its First Night Out 2 Weeks Ago It Turned A 11.90 1/4. With 3.91 Gears.the Kit Works Nice.comes With Cushioned Fuel Line Mounts.really Works Well.delivers Plenty Of Fuel.the Summit Kit Is The Way To Go If U Are Wanting Braided Line.20 Ft.is Plenty To Do The Whole Car.as U Will Not Need A Return.
