Challenger
could someone tell me what the ohms should read on fuel sender from empty to full on 69 dart thank you
According to service manual Empty should be 73.0 ohms plus or minus 12.0 ohms. Full should be 9.6 ohms plus or minus 1 ohmcould someone tell me what the ohms should read on fuel sender from empty to full on 69 dart thank you
Yeah, but who has a C-3826 tester on hand?Somebody else created this photo, it's the rear of one of the factory test tools
thanks for the reply guysWell... A gauge tester isn't a sender tester. It's quite possible that those yellow letters were added w/ms paint shop or photoshop. Oil and temp senders can go beyond the 80 <-> 10 ohms range too. So what applies to testing a gauge doesn't exactly apply to testing a sender. A fuel sender does have positive mechanical stops and should show more or less a 80 <-> 10 ohm range. It's not linear though so 1/2 isn't 35 ohms, it's 23 ohms. Yes those yellow letters are correct, added on or not.
For what its worth... 80 ohms should get no needle movement so testing all the way down there wouldn't be a test, only a question... "Is this thing on?".
About 73 ohms will get about the first hash mark on a 80 <-> 10 gauge.
