Fuel injection throttle body
Fuel and Air Systems
  1. ClassicCarGuy
    ClassicCarGuy Well-Known Member
    84
    19
    Feb 6, 2018
    Suburbs Phila Pa
    Local Time:
    9:07 PM
    Has anyone purchased and installed a fuel injection throttle body system on there car?
    If so:
    What brand system?
    Used on what size motor?
    Do all brands use an in tank fuel pump?
    Would you please provide both positive and/or negative feedback regarding the brand you installed.
    Finally, how did you determine what size system to install?
    I’m not a mechanic and will have someone qualified do the installation so please please keep my lack of technical knowledge in mind.
    Thanks for your help!
  2. Steven190
    Steven190 Well-Known Member
    1,234
    627
    Jan 13, 2012
    Omaha
    Local Time:
    8:07 PM
    Good bet is the Holley Sniper up to a mild modified motor. Can use a fuel pump outside the tank, needs a return line. and an O2 sensor in exhaust. Can handle up to 550 horse power.
    Good results. I used a Fast 2.0 on my 408, a little more expensive and more hardware.
  3. ClassicCarGuy
    84
    19
    Feb 6, 2018
    Suburbs Phila Pa
    Local Time:
    9:07 PM
    Thanks for your response and feedback.
    What are your thoughts on a 416 450hp 486 torque?
  4. Steven190
    1,234
    627
    Jan 13, 2012
    Omaha
    Local Time:
    8:07 PM
    nice combo, and the Holley will work
  5. dano
    dano Evil Handy Man
    3,510
    1397
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    6:07 PM
    • Like Like x 1
    • pishta
      pishta I know I'm right....
      19,138
      8559
      Oct 13, 2004
      Tustin, CA
      Local Time:
      6:07 PM
      ^^^ That's so cool! ^^^ That black thing must be the ~44 psi regulator. The old Ford TB's used about 14 psi and ran off a stock looking mechanical fuel pump. Not sure how they cold started, maybe they used an accumulator/filter like the mechanical Bosch Jet-tronics. That was a 4 micron filter!
    • 1994redram
      1994redram FABO Gold Member FABO Gold Member
      1,299
      719
      May 9, 2012
      Oklahoma
      Local Time:
      8:07 PM
      I have a holley sniper on my Magnum based 408. I used the drop in holley in-tank fuel pump. I love it and haven't had a single issue with it. I even used the factory steel fuel line. I just capped the return fitting off on the sniper throttle body.
      FYI. The holley pump assembly uses a Walbro pump. They are readily available and VERY popular pumps.
      • Like Like x 1
      • Thanks! Thanks! x 1
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        46,568
        14433
        Oct 14, 2010
        Idaho
        Local Time:
        6:07 PM
        By the way somewhere, someone on here did a "diy" slip-in-the-tank Walbro style pump that's "a bit cheaper" than the Holley setup
      • AndyF
        AndyF Well-Known Member
        1,903
        2093
        Feb 23, 2009
        Oregon
        Local Time:
        6:07 PM
        The Holley Sniper is good for up to 650 hp so no problem supporting your engine. There are a few different Sniper models so you just have to figure out which one you like. The Stealth model looks like a carb and the factory throttle linkage will line up properly. The square Sniper is wider than a carb so the throttle linkage has to be adjusted. I highly recommend adding a Hyperspark distributor so the Sniper can control timing. The 12-319 drop in fuel pump module is the way to go. It makes the install super easy.
        • Agree Agree x 1
        • famous bob
          famous bob mopar misfit
          18,380
          7747
          Aug 14, 2011
          okla
          Local Time:
          8:07 PM
          Fast 2.0 is supposedly good for 1200 h.p. , "not that I`m approaching that" ! I had to down grade my cam a little to make it have enough vacuum to run right .
          That being said , the most knowledgeable guy with fast has gone to work for edelbrock , I `ve been told .
          Mine is working pretty darn good so far !
        • Steven190
          1,234
          627
          Jan 13, 2012
          Omaha
          Local Time:
          8:07 PM
          I am running the Fast 2.0 on my 408, I love it.
        • Coyote Jack
          Coyote Jack Member #55, I'm old FABO Gold Member
          8,617
          2765
          May 22, 2004
          Baxters Corner N.B. Canad
          Local Time:
          10:07 PM
          I have a FiTech 2x4 1200PA system. It's on a 340 with 6-71 roots blower. Maximum hp of engine is about 700hp, maybe a little less. I used a Walbro 392 inline pump. It has timing control but I don't use it. I am a fuel only application. I did my homework before installing and shielded all the wires so there would be no chance of cross talk from electrical components and have not had a problem since I put it on 3 years ago. Sure beats the carb setup I had.
          Jack
