homeboysduster
it has been a long time sense I have been on!!! but, is there a big block made that can be made to take fuel injectors?
You can inject just about anything from a Brigss and Stratton up. Many many ways to approach the problem
The new Holley HP/ Dominator/ etc stuff has versions that can be programmed with a handheld device and are "self learning," or you can piece stuff together using Ferd, or GM ECU Lots of dope.
Wander over to the "binder planet" where many guys have modified IHC engines using GM ECUs,
or Google up "Megasquirt"
http://www.diyautotune.com/?gclid=CNuY4Ku55rUCFe9aMgodrQYACA
Cool stuff......but I think I will (sooner or later) be sticking with a conventional throttle body
I have to admit I like your set-up the best so far!!!! I am looking at building a intake that gives a hint of a 6 pack!! or in my case an 8 pack!!!!!:burnout:Mine Autronic EFI system, Bosch Motorsport injectors , twin 044 Bosch pumps
60mm butterflies drives crisp, clean and mean !
11.2 @ 119 MPH 1.54 60'
only a chevy guy could hate that!!!LOL that is just awesome!!!!Lol check out the sticker I had made up when I got my beast on the road back in 2006' this will get you and the guys talkin.
All the best !
