Fuel Line?
SSing
upland, sweden
Hi,
Do the 3/8 fuel line on BB Barracudas end any different, than the 5/16 line do on the SB cars?
Guess not... but since the fuel pump is in a slightly different location in the engine compartment... want to make sure.
Picture show 5/16 line in a ´68 SB Barracuda, and measured from radiator support.
19" some...
And also did the Dart use a longer fuel line due to the longer wheel base?
Thanks
Stefan
I don't know how much difference the BB engine would be. Of course a 3 inch longer car would have a different 3 inch longer hard line.
The BB lines should be the same and should route from the pump to the carb the same.
Yes, I should have thought about that, since the 3" is between the wheels, and the line has to be 3" longer in this section to fit, not front or rear section :)
thanks
