Thanks for the reply's guys. They should solve my problem.
As far as the 5/16 line.
Well, it's like this. I can't see my car doing any better than 11.80. With that in mind I did some calculations and with the 360 and a 750 on top of it a 5/16 line is plenty big enough to supply the gas I will need. This also means I don't have to change my fuel pump or my pick-up in the gas tank which are both in good shape. Saves a few dollars that can be used elsewhere. Like 383man said, his sons dart is faster than mine and it works well with the 5/16 line. I don't mean to sound like a smart *** here, but it always pays to find out as much as you can before you do something on these cars. If you put something on, that the car doesn't need or won't use close to 100% then you are wasting money on useless bling.
Jack
