Fuel Pump Block Off Plate
805moparkid
Slant and AFX Guy
Anthem AZ
are they the same as a 440 and what not?
couldn't find a dedicated one for a slant six...
thanks guys!
As far as I know the small block plate works on a slant.
Not sure about the BB.
Going electric ?
What pump you plan on using ?
I was thinking about going electric and using a Carter #4070.
If I remember right its set between 6-7 lbs.
Says you dont need a regulator.
Going electric ?
lol same pump... my boss man had 3/8 line and that pump sitting on the shelf and i said i'll give you 100 bucks for it... sold! got the pick-up already to!
just make sure to re-set your floats because the 3-4psi the stock mech puts out is nothing vs the 6-7 the electric puts out and you'll flood really fast!
Cool, look forward to seeing how it works out for you.
You can work all the bugs out for me.....Lol
You going to run a regulator ?
