Fuel pump question
chorty55
Usa
Who's seen a 4 bolt plate between pump and block?
More horsepower edition?
Looks like a small block Chevy fuel pump block off plate was being used as a spacer- Lord knows why-
and then the pump came apart?
Sure did fall apart. Looks like newer one doesn't have that return spring.
And the cam gear isn't nylon/plastic, but wow that chain swing!
Easily a half inch.
I'm kinda worried I should pull the cover.
Agree. That 4-bolt plate looks like a smallblock chevy fp mounting plate (not a blockoff).
No idea why it was used as a spacer, unless the pump being used was wrong too.
