Fuel Pump
roccodart440
What fuel pump (mechanical) do you guys recommend?
Mine is all gummed up and i'm just going to get new. I've already bought a new tank, sending unit, fuel line and straps, bolts, grommet etc. Might as well get a new pump.
Also, I'm not sure here but it looks like a hemi and a slant 6 pump are interchangeable?
I use the USA made pump sold by Auto Zone. They are made up in Ohio Ive been to the plant a few years ago. Cost is about $25 retail and has a 1 year warranty. No need for anything better unless you are really building your slant up for race only.
Frank
I'll check it out and see if they stock it.
The carter 60577 is for a 225 as well and is 33.99 on summit
Still by looking at the pictures it appears a hemi pump and a slant six pump are interchangeable.
I am working on a street/strip build
Correct. I do not want to run a regulator.
Was also thinking stock pump in front and Holley red electric in rear. I have one of those sitting around.
Here is my dilemma. I have 1/2 inch fuel line from front to back so I need a mechanical pump with a female inlet.
I picked up an adapter. 1/2" nipple to 5/16th. It will have to do for now.
