Hi Bill
Like I have said, I have absolutely 0 experience with turbos.
Might want to find out what the other turbo guys are running for fuel systems.
But if you think you need 45psi, I believe you.
Most EFI pumps I have seen generally put out between 30-70 psi.
So,if you need 45psi,with a regulator of course, your in business.
Have been following your build, and am anxiously waiting for the unveiling...:thumblef:
We won't see 30 pounds of boost for a long, long, time (if ever) but, that is our goal.
The thing is, the /6 is such a STRONG engine in terms of its ifrastructure, we 'd like to know what its limits are, if it has any, (and undoubtedly, it does) but we're going to start out with 10 pounds of boost and work our way up, slowly, from there. There are a couple of guys on this BB who routinely run boost levels in the mid-20s, and they go pretty fast with that setup. We are not convinced that more boost would do anything destructive to the motor, so unless we find out otherwise, eventually, we plan on testing the limits of this little brute.
But, first things first.... we've got to find out if it will even run, before taking that next step.
Neither my racing partner (Freddie,) nor I, have
any experience with turbos OR slant sixes, so you can see that the learning curve will be pretty steep...
Throw in the combined ages of him and me (145) and, you can begin to appreciate what a stretch this whole operation is...:toothy10:
Hide and watch... this could be funny!!!
