panoply
Member
On my two Darts, the gas gauges work but both prematurely retreat down below the empty line. They pretty much lay at empty after 100 miles or 7-8 gallons, so I know there’s 10 gal more to go. Then the needle will eventually lay down below the empty line and At that point, I’ve determined, that they actually are still holding 4 gallons in the tank.
Is this common? Any ideas.
Thanks
Thanks
