WAYNE0
I have 360 397 ci engine that i just installed a paxton super charger & a quick fuel blo-thru carb. I also installed a holley muscle car intank fuel pump/ sending unit 350lph 58psi non return. I just installed a quick fuel regulator non return 2 outlets 1 inlet 4.5-9psi 1:1boost reference. When i start i up it runs rich. So i checked the float level & it was high. So i adjusted it. Also adjusted the regulator to 7. Stated it up & still running rich. I noticed that the float level was going up by its self and so was the fuel pressure at the regulator. I had a friend of mine come by that knows more about carbs than i do. He took the bowls off & couldnt find any thing wrong with the carb. When we took the carb off the bottom of the intake was wet. We took the carb off twice & both times the bottom of the intake was wet wheather we ran it or not. Not sure whats going on. Anyone have any ideas ?
