Fuel tank 1961 Plymouth Valiant V200
Tom Land
Member
Andover
Can anyone help me locate a new, used, after market, or constructed from spec fuel tank for a 1961 Plymouth Valiant? Thanks.
I have a clean used tank and filler neck and and new sending unit I believe is for a first gen Valiant.
Where are you located ?
I'm in Northeastern Massachusetts. Could you possibly send photos of the pieces, so I can compare them to what Is on the car right now? Thanks.
In a few hours (after 9 am PDT this morning) I'll be able to access the tank and sending unit and filler tube . Then I'll post pic's here.
Here are the dimensions 30" x 15" x 9.5"
Now for the pic's ....
You know how you put something away years ago and you know where it was and then it gets moved several times . Now you don't know where it's at .
Now I have to hunt for the filler tube and the new sending unit . They are somewhere in the building ... but where ?
This looks great. Let me know how much the whole set will cost (plus shipping) once you locate the pieces.
Sure, do you have a good sending unit and filter ?
I have a filter and a sending unit. I'm pretty sure the sending unite works, but the filter is suspect. I've checked online and it appears that I can get both. The fuel tank was the hardest part to find. How do we proceed? The site recommends offline conversations. If you can check on express shipping that would be my preference. Tom
