Yote
Fuel tank in my 72 demon needs cleaned badly. What do I need to know about removing the filler tube . Also what is best process for cleaning the tank once removed?
Another item, I have a trap door air cleaner, where does vacuum line attach to carb? Carb is Carter thermoquad with one port on left front and two ports on rear to which choke is attached to right port and distributor on left.
