Fuel, temp, oil pressure, radio, wipers, blinkers etc not working
ESP47
Sacramento, CA
This is on a 75 Dodge D100. I was running late to work today and haven't had time to even mess with anything but I noticed all the parts I listed in the title weren't working on my commute today. The headlights, alt gauge and dash lights all worked. I popped the fuse box cover on the dash and looked at the fuses real quick and didn't notice anything blown. I'll take a multi meter and check later on today. Just wanted to see if you guys had any ideas for me while I'm stuck at work. Thanks.
1....Thrash around the various truck forums and see if you can find a factory service manual to download AND POST that link here
2....I'm not as familiar with wiring in these, I'll look around. It's possible there is additional fuse links in these girls
3...My immediate thought is the accessory buss feeding out of the ignition switch. Get a test lamp or meter and see if you have that voltage. "Generally" the fuse panel has TWO supply buss's. One is hot at all times for things like tail lights, brake lights, horn, the other comes out of the ignition switch "accessory" feed.
So start there at the panel, then check the igntition switch connector under the column.
Closest "quick" thing I found is at MyMopar has wiring for 68-71 and then 79
http://www.mymopar.com/index.php?pid=24
