I have a 7 fuse block out of a 73 dart sport 5 - 20 A and 2- 3 A . what fuse does what? Jim
go to www.mymopar.com & get to the wiring diagrams. EDIT click on "tools/reference" in the main menu to the left then click on wiring/electrical diagrams then click on "Mopar wiring diagrams" then click on your year/make. it'll have the orientation (front to rear) so to speak but not the amps of the individual fuses but with your fuse block in hand you can easily orient it & know which is which. I know the heater is 20 & the dome lights are 3, AC is likely 20 alsoI have a 7 fuse block out of a 73 dart sport 5 - 20 A and 2- 3 A . what fuse does what? Jim
thanks Rapid will check them out right now Jimgo to www.mymopar.com & get to the wiring diagrams. EDIT click on "tools/reference" in the main menu to the left then click on wiring/electrical diagrams then click on "Mopar wiring diagrams" then click on your year/make. it'll have the orientation (front to rear) so to speak but not the amps of the individual fuses but with your fuse block in hand you can easily orient it & know which is which. I know the heater is 20 & the dome lights are 3, AC is likely 20 also
