Yes, Sir. Thank!I am assuming that's .050 duration figures? I've built an engine with those pistons and I can pretty much assure you the valve reliefs are plenty generous.....that said it's not the lift you have to worry about.
Yes, Sir. Thank!
I get that it’s btdc/atdc say 10*/10* after that’s the issue.I am assuming that's .050 duration figures? I've built an engine with those pistons and I can pretty much assure you the valve reliefs are plenty generous.....that said it's not the lift you have to worry about.
