bmw88rider
I have a 66 barracuda that I've been slowly fixing issues on. I pulled the motor to clean up the engine compartment and refresh the motor. I pulled the weatherstrip and there was an almost 1 and a quarter inch gap between the inner and the outer fender at the top that was filled with spacers.
So A body Guru's should I be concerned that there are big issues in the front of the car that need corrected or is it semi common occurrence?
