fishy68
Tyr Fryr's Inc.
Brand new Sealed Power high volume oil pump. It's clearanced it so it'll clear the main bolt/stud fine. $40.
Nice used 5/16" ball and ball pushrods. They are 7.61" long so their real close to the length needed when you install magnum heads on a LA block and their oil through so they should work fine. $30
Used double roller timing chain set. I tried it on a engine I have and it fit with no slop at all. $15
Windshield washer tank and motor. Good condition and the motor works. Not sure exactly what it came off of? $30
2 hole gauge panel for 2-5/8 gauges. Black. Good condition. $8
Used OEM battery cable from a 68 Cuda. Worked fine but has a spot on the small wire that leads to the relay that is bare. $15
All parts plus shipping or you can pick them up in central Illinois 45 miles n.e. of St. Louis
