Sedanman
67-9 Valiant specialist
70-up non a/c w/ ps steering small block pullies and matching alt bracket $60 (sold)
67 273 block and heads & pistons std bore $150
11x2 rear brake backing plates $40
67-up 2 speed wiper motor $20 (pending)
K&N 14x3 drop base air filter chrome top & bottom $40
67-72 wiper pivot set up $30
BB spool motor mounts $40
VDO guage set with engine fittings for small and /6 engines $60
small block dip stick and tube $20
door hinge bolt set $5 (pending)
8 3/4 stud & nut package $25
manual brake push rod & boot $20 (pending)
fan spacer $5
auto gage tach $30
small block plug wire holders $20 (pending)
66-up console ash tray,slide cover with nuts and tracks $30
A body bumpar jack assy $50
67-76 stainless door edge guards $50 (pending)
68-up screw in retractable antenna mast $25
a body working washer bottle $25 ea,I think I have 2 (both pending)
new abody cowl to hood seal $25 (pending)
66 & under window cranks $25
67-9 valve cover breather $20 (pending)
67-76 door sill plates $25
67 valiant owners manual packet $25
empty packet $10
nos 67-72 door locks with keys $40
set of door lock with wrong keys with rods $10
Door hinge repair kit $10 (pending)
trunk lock assy no key $10
dome light lens $10 (pending)
misc antenna nuts & bezels $10 (pending)
misc bag of brake switches,starter relay wire guard,glove box light,carb bolt,wing nut,heater core bypass tubes $10 (pending)
gas tank filler trunk seal $10
2 bags of misc chrome lug nuts all 1/2 $10
aftermarket cruise control set up removed and working from a dart $100 with all manuals
valve cover plug holders $10 for all (pending)
72 hood scoop (not mine) in pretty nice shape but missing lower plate and has 2 broken tabs $175 obo
67-9 plymouth horn center $20
spare tire bolt and wing nut $10 (pending)
valve cover oil fill extender $10
coarse spline pinion yoke for small joint $25
All parts + shipping or make me an offer and take it all minus the scoop
fan spacer $5
auto gage tach $30
empty packet $10
