Gas Leak around Filler Neck
greyghost340
GreyGhost 340
New Balimore MI
I am working with a 1973 Dodge Dart that has developed a leak where the filler neck enters the tank. I have removed the tank several times and never changed that Grommet. Does anyone know where I can purchase the rubber grommet that goes on the gas tank where the gas tank filler neck enters the tank? :BangHead:
My first replacement grommet was from Classic Industries. Lasted 1 1/2 years, then cracked and started leaking. The second grommet from Year One and has been in there for 3 1/2 years. So far, so good!
Right that is the difference. Jim (DMT) uses the same material as OEM.
