Gas leak Holley 1850
4drzdart
Member
Montreal south shore
Hi guys,
been a while I came here ... but did not touch the car for a while also ...
anyway the car has been stting in my garage for almost a year without being started. I just changed the intake, reinstalled the carb and tryed it.
Surprise !!! gas was spraying from the tube connecting the two fuel bowls. I retighted the bowls 4 bolts, same result.
Removed the carb, removed the bowls, and saw that the o-ring were kind of dry. I have redone the carb, about two years ago, with a gasket kit that I got at Stowe flea market.
Turns out that o-ring, good for gas, are unavailable around here.
I tought I could put back the tube and the bowls, and pack the opeingin around the tube with black RTV. Anyone ever used black RTV for something like that?
I hate those Holleys with the transfer tube...I always change out the bowl to the dual center hung bowls...
probably not the answer you want....
[ame="http://www.ebay.com/itm/Holley-4-barrel-26-37-Carburetor-Transfer-Tube-O-Ring-Seals-/261647179840?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ceb632040&vxp=mtr"]Holley 4 Barrel 26 37 Carburetor Transfer Tube O Ring Seals | eBay[/ame]
that sucks ... sold a 750cfm Holley with that setup, the bowls your are talking plus the chrome tube to feed them, to a good friend ...
Look for an old holley with those bowls....
Get the list # off the air horn and order a Holley rebuild kit , it has the O rings you need . I wouldn't use RTV , summit or jegs has the kit you need .
X2
My little 600 Holley got that treatment many years ago. never looked back.
If the o-ring is still in good shape lube the o-ring with dialectical grease and gently put it back together.
Do NOT us RTV, gas will eat it and turn it into slime!!!!
I was just trying to avoid getting a new complete kit, since the rest is new ... and it's always a bit more complicated to get stuff here :banghead:
But if nothing works I will go that way.
X2
Will try that dialectric grease, might be enough, since the o-ring did not looked crack just a bit dry.
Thanks guys :thumbrig:
