gauges on the cowl?
Cope
Fusing with fire
San Jose, Ca.
I like the look of gauges on the cowl.
I know fuel PSI must be out side unless digital or isolated from driver compartment.
What else do folks run on the cowl?
Typically oil fuel gauges. I run a fuel gauge on my duster, the oil pressure i have under the dash
Boost, oil, fuel.....hell, I've seen um all out there at one time or another......but I'll say this about it. It's a real 80s thing to do and can look super cool IF done well. On the flip side, it's REAL easy to make it look like total crap. So be careful.
What do u think makes em look like crap?
What makes it look good?
Nice bass.
Nice bass.
Stuff like exposed wiring and brackets look like hell. Fuel and oil lines that are plain and not nice steel braided look bad. That's one of the FEW places that I go along with steel braided stuff......cause it was an 80s thing and goes well with hood or cowl mounted gauges. Makes it look nice, IMO. The cleaner the better.
The GTO was the only car that looked good with a hood tach, IMO. Particularly the 68-70 models.
I run the factory gauges. I'm a streeter, and I don't care for the, IMO, clutter. It's a 2-gears to 65mph car so even the tach is questionable if I need it. I only installed it to go to the track this one time And it "lied "to me the whole way, being more or less "stuck" on 7000, from the 60ft mark and on..
lol, no hook.
Yeah, I realize Ima bucking the system, but I very rarely look at the gauges anyway. And if something was to go wrong with the engine, by the time I would find the gauges, focus on them, and interpret the results, the engine would be toast anyway.
7000 rpm is about 117 revolutions per second.You can hear a rod before you will see it on the gauge, unless the mechanical gauge is in your face.And your eyes are a lot younger than mine.And then if you are quick enough to clutch it, and kill it, it will take at least another 117 revolutions, or more, for the engine to come to a stop. If you hesitate for just 1 second, now we are up to 351 babbit pounding revolutions. But if the bearing has spun, which is typical, then it has been pounding steel on steel. So here's a challenge, go out to your garage and find the biggest hammer in the tool box, and go smack your anvil as hard as you can for 350 smacks. See what I mean?
So what good is it to know what your oil-pressure is, by this time.
I built my engine to last, and it has gone 100,000 plus miles and was installed in 99, and running down the road in September of that year.I'm nobody special, anybody can build a street engine like this.
But if you have made up your mind to put some gauges on the cowl, there are some pretty good tips here!
Or see a rod before you hear it on the gauge, or something like that. :D
One thing about outside gauges is you pretty much have to use marine gauges unless you never plan on it getting wet.
Dammit I should have glued that gasket on the scoop....
Still gotta cut the studs of the back of the gauge to get it to sit fully in the cup and twist the gauge and cup just right but it was a long day at work and I just got tired....
I like it and I know my pressure regulator is working....
Also gotta put in the grommets so the Braden line sits up nice and won't chafe but that's why we have tomarrow. ...
id be worried if my fuel pressure gauge read that low...no wonder you want to keep an eye on it ;)
I got to burn a little ricer on the way home from the shop and she said 6 PSI all the way past his car... I did lift as I had one beer and 4 more cylinders....
May take her out this weekend and see what she has to say at WOT....
The Rebel machine looked good also with the hood tach.
My Duster also looks good with the hood tach:
