Gear change?
Backally
Wisconsin
70 Duster, 340 4spd. Presently have 3.23 sure grip with 26 inch tires. If I go to 3.55 gears and 27 inch tire, will the taller tire negate the advantage of the lower gears? Looking for a little more punch around town.
Thx. May have to rethink this. Want a little more get up and go, but not enough $$$ yet for the engine upgrades I eventually want.
Yeah it'll pretty much negate the effect of the lower gear ratio. Not just because the taller tire lower the rpm like a taller gear but those taller tires weigh more and take more energy to turn them. The good thing about them is taller tires generally hook better.
If you went with the taller tires and went to a 3.73 gear you should notice an improvement.
