kiss
My 71 Dart has a rimblow wheel and column. The light has been burned out on the gear selector for as long as I've had the car. How do I replace this light? I assume it requires extensive disassembly of the steering column?
Check and see if the indicator lens has screws to hold it in place. The indicator lamp is directly behind it. It almost looks like it comes out the back of the opening.My 71 Dart has a rimblow wheel and column. The light has been burned out on the gear selector for as long as I've had the car. How do I replace this light? I assume it requires extensive disassembly of the steering column?
Thanks. There were 2 screws holding it into place. I managed to put it back together and it works!Check and see if the indicator lens has screws to hold it in place. The indicator lamp is directly behind it. It almost looks like it comes out the back of the opening.
What does your steering wheel look like! Just curious.Thanks. There were 2 screws holding it into place. I managed to put it back together and it works!
It's a rim blow like this oneWhat does your steering wheel look like! Just curious.
