I have a Gear Vendor over drive behind my 904 with 410 gears in a 8 3/4 rear end with a pretty much stock 1970 340. and trying to learn how to shift it through 6 gears. can anybody give me some advice and thanks in advance.
mine is not set up with a manual valve body I guess I should. Been shifting the tranny then the over drive. seems to work ok but I gotta stay on top of it or I'll miss a gear. this is new to me so forgive my ignoranceA manual valve body and a "Hi/Low button on the stick..........
yea got that but 2nd over drive it pulls real hard then third then third over drive seems to me to work better than 3rd then over drive but maybe it's just the excitement of trying to go through the gears.1,2,3, overdrive 4th
so true I got it down pretty good but not sure if it's worth it.The problem is you have to connect and disconnect the overdrive in every gear, That takes time.
never had my car at the track so never knew if it helped splitting gears. thanksI have that setup in my Barracuda. As quick as my car goes through the gears 1-4 is as fast as I can react.
I know that to try to split/shift it would be way slower and cost time in the end.
dam hard to look at what you posted with that cuda looking at me nice car
it sure is nice to cruse at 65 at under 3000 rpms
Thanks!dam hard to look at what you posted with that cuda looking at me nice car
seems to me the gear vendor works great with a stick. as far as I can see it has been the best thing I ever done with my car never have to change out the rear end to go long distanceThanks!
Working on a 69 Barracuda Fastback now for my son that will have a GVOD behind a Full Manual RVB 727.
Will put one in my E-Body behind the A833 after we finish the 69.seems to me the gear vendor works great with a stick. as far as I can see it has been the best thing I ever done with my car never have to change out the rear end to go long distance
sorry but it's my turn to win the lotto,my next car is a 70 440 six pack cuda 4 speed in lime green and then a 68 or 69 cuda with a small block and a supper charger. you are living my dreamWill put one in my E-Body behind the A833 after we finish the 69.
List of stuff for the 'Cuda waiting until we finish the B'cuda or win the lotto whichever comes first.
lived in Washington most of my life around Tacoma, Graham, Fife. worked in the ship yards on the new cars that came in off the ships. Got tired of all the traffic and bad people and of course the rain. sure do miss it there but can't put up with all the peopleWill put one in my E-Body behind the A833 after we finish the 69.
never read it till now thanks that helps a lot.Did you read this?
Operation Tips
yea your right AJ I have to really be care full on my shifts it works well if I shift the tranny first and as I shift and before it goes into 2nd or 3rd hit the overdrive then it works well but sometimes I miss, but getting better. good to here from youHey Fred,
The 904 ratios are too close together to take much advantage of splitting, but more importantly, I was told by GV that you cant have the power going into the unit on the outshift. That is to say you can put full power into it on the upshifts; as in from first into 1-od or from second into 2-od. But when going from 1-od into second, the power has to be interrupted until the box has outshifted. And as you have discovered,. that vcontrol module has a time-delay in it, so that really sucks.
To be continued
and not sure if there is any help in splitting between 1st and 2nd but plan on taking her to the 1/8 mile track this summer for the first time for the car. And I only tried the 1/4 mile twice back in 1978 I think it was.yea your right AJ I have to really be care full on my shifts it works well if I shift the tranny first and as I shift and before it goes into 2nd or 3rd hit the overdrive then it works well but sometimes I miss, but getting better. good to here from you
Try not to miss too often, the repair bill is 50% of the current retail price, plus shipping, plus several weeks down time. I highly recommend you only use it as your final shift. At least until you get confirmation from the manufacturer.and not sure if there is any help in splitting between 1st and 2nd but plan on taking her to the 1/8 mile track this summer for the first time for the car. And I only tried the 1/4 mile twice back in 1978 I think it was.
