LJS30
Has anyone put a Gear Vendor Overdrive unit onto their 904? Is this even possible? If so, how expensive and how did it work out?
I have not used one but did look into it once for a 727 and the kits are about $2500. I instead bought an A518 because it was much cheaper. A500's shouldn't be that hard to find. I bought a core A500 in a wrecking yard for $50. It can be rebuilt for a lot less than $2500. With a Gear Vendors you can split every gear but that would be the only real advantage to it.
Chuck
