Gen 2 hemi swap
felixcoupe
New Member
Puerto Rico
Hi guys. Need a little help with a gen 2 hemi swap that I want to do to my 73 dart sport. I have the headers, elephant ears, master cylinder offset mount and transmission set up. My question is about the steering gear and linkage and the shock towers. Any help or pointers are really apreciated.
Not that they're absolutely necessary, but they also had spacers between the K and the frame. Since you're using elephant ears instead of the K frame mounts, it may not even be relevant.
As far as the pitman and idler, the original LO/BO cars had the big block idler arm, but that was about it AFAIK- but those aren't useable on '73 and up.
Shock towers were clearanced with a sledgehammer by Hurst.
The K frame for the Hemi is unique, due to the different motor mounts that bolt to the block. The elephant ears is probably the easiest way to mount it. I did my swap from 440 to Hemi and only changed K frame in a 71 Cuda and no interference problems. A body is a different animal though.
