[SOLD] Gen 3 hemi th400
psycomopar
mn
Rating - 0%
0   0   0
Selling a th400 that I had built for a project that I ended up selling. Stock th400 case cut for jw bell 6 an cooler lines and a 4an vent fitting . coan billet promod 36 element sprag and drum ,sunnex rollerized forward clutch hub and coan solid input shaft.,rollerized rear tail shaft. Coan 6/6/5 clutch setup with billet pistons. Case saver. Jakes performance billet transbrake 1-2 leave valve body. Jw th400 small block/ gen 3 hemi bell housing. Jw flywheel with ati crank adapter. Moroso deep aluminum pan with tci filter new Power master starter. Looking to get $5000 for the setup. Was built to handle 1300 whp
