Gen 3 Oil Pan Packages
408 swinger
Iowa
Holley Gen III Hemi Swap Oil Pan - VVT
Cool deal. Anyone else caught this? Seems like a real decent alternative to Milodon stuff. Very cost effective when comparing not only the pricing, but, quality and construction. Cast with that o-ring gasket, should NEVER leak. Available for all generations of the gen 3. I'l definitely be keeping this in mind.
I am debating on buying one myself now for my 5.7; I do like the Kevko pan better but when you add up the extras it is more expensive.
I'll have to check Kevko out. They're fairly local to me. About 2 hours away. Wasn't aware they made pans for the gen 3. Thanks!
I think the Kevko is a better pan to be honest but its about $160 more money if you get all the parts (windage tray, studs, pickup, etc.). I have one of their pans on my 73 Cuda and really like the construction and fitment not to mention the baffles in the pan, plus Kevko was great to work with. The first pan I ordered from them was the wrong one, totally my fault. When I called them they said "no problem", I just had to pay the difference between the pan I got and the pan I needed, they sent me the new pan with a return label and I sent the other one back.
I've used their pans on a few dirt engines I've done for customers. Never have had any problems. Yes, they do have good customer service. I would be curious to see if the fitment and seal is good on the gen 3. Some people have complained about the Milodon leaking. I, personally, have not had issue with them.
