Gen 3 pinouts anymore?
Effingham
Im looking for the 2003/4 pinouts, diagrams, how-to's from years ago which showed you which pins on the c1/c3 connectors you needed to send to 12+, ign, and ground to convert it to stand alone. DIY Hemi used to be the place, but not they just sell parts. Any ideas? I have searched high and low. I have used the mopar connector repair site and have some idea, of possible ones to splice, but hate to tear up my harness guessing.
Thanks,
Jeremy
I thought AutoZone of all places used to have some manuals and information like that online. I know I had found some diagrams and specs there in the past, but it's been a while since I looked, so not sure if it might have changed.
You could look at a AllData. It's a small cost, but you can print wiring diagrams and such there.
I haven't looked for '03/04 pinouts since (as I understand it) they are a bugger to try and swap, but I have a service manual for an '04 Durango. No idea where I got it so I can't point you to a link. I can clip it down to the C1 to C4 pinouts, but I have to email it since I can't attach a pdf here. If you want it, PM your email address and I will send it to you.
The other option is to search for service manuals. You might find what you are looking for in those.
I have a pdf of a 2006 Dodge manual with wiring diagrams. I could email it to you.
I have a pdf of a 2006 Dodge manual with wiring diagrams. I could email it to you. View attachment 1716347056
Just be aware that '06 is probably completely different than '03/04. My understanding is the '05/06 are similar but they made some significant changes compared to the previous years. Don't remember exactly what though.
Frankly, if it was me, I would do an '06 setup on it regardless of what year the motor is. Pretty sure the sensors can be swapped if need be so the motor won't care. I think the electronics of the '03/04 make it a bunch more work.
