CLAY72dart
How close is cutting a 318 at a machine shop to a natural 340. Trying to build the one I just got.
I’m looking to build it to 400-450 hp I should’ve wrote that earlier. I don’t care about size of the bore as much just thought bore size directly equaled more horsepower.All you need are 318 pistons to work with 360 heads. See post #7 above. The rest is the same. Horse Power is in the heads, not the cubic inches.
318 bore is more than capable to make 400-450 hp, rpm might be the problem, depending on you 6000-6500+rpm will probably be needed to make 400-450 hpI’m looking to build it to 400-450 hp I should’ve wrote that earlier. I don’t care about size of the bore as much just thought bore size directly equaled more horsepower.
Here's all the 318 plus for the 318 guys
318 Engine Build - A Parts Book 400HP 318 - Mopar Muscle Magazine
Mopar 318 Engine - Car Craft Magazine
Chrysler 318 Engine - Popular Hot Rodding Magazine
318 Small Block Build - How To - Hot Rod Magazine
318 Long Block Bolt Ons - Tech Articles - Mopar Muscle Magazine
Iron-Headed Mopar 318 Magnum Engine- Popular Hot Rodding Magazine
318 Engine Buildup & Dyno Test - Mopar Muscle Magazine
How To Install A Hotter Camshaft - Mopar Muscle Magazine
1985 Dodge Dart - Mopar Performance Magazine
Vintage Mopar Power! 550HP Chrysler Poly 318 V8 on the Dyno
318 head porting for the average joe
Porting small block 915 j-heads
Magnum head porting for the beginner
360 Engine Head Porting - Mopar Muscle Magazine
Porting Exhaust Smog Heads - Mopar Muscle Magazine
Cylinder Head Porting - Mopar Muscle Magazine
Mopar Small-Block Intake Manifold Flow Test
https://www.hotrod.com/articles/0601em-intake/
https://www.hotrod.com/articles/10-critical-mopar-engine-building-specs/
https://www.hotrod.com/articles/mopp-0309-mopar-engine-rebuild-intro/
https://www.hotrod.com/articles/mopp-0308-adding-magnum-to-a-360-short-block/
I read somewhere that the valve train in the 318 usually fails to get to that rpm. Something about the play in the rods affects it.318 bore is more than capable to make 400-450 hp, rpm might be the problem, depending on you 6000-6500+rpm will probably be needed to make 400-450 hp
I’m very unfamiliar with building motors.I read somewhere that the valve train in the 318 usually fails to get to that rpm. Something about the play in the rods affects it.
Rings seal?How well your rings seal makes way more difference than bore size!
I don’t want that.The more metal removed, the weaker the cylinder walls become.
You probably should be shopping for a competent engine builder.I’m very unfamiliar with building motors.
On the powerstroke the better the ring seal the more force applied to the pistons.Rings seal?
RED X ....Really??Or.... look for a decent 360 core.
