GM EOS is back
A readily available subsititue is Comp Camps, break in additive. It is available from all the mail order suppliers, or a local speed shop. Add one bottle to each oil change, and the flap tappet worries are solved.
Yes it does. I put STP oil additive in my 318 with every oil change. If you look on the back of the bottle at the ingredients you will see "Zinc dithiophosphate".
I think what he meant was that it doesn't have enough zinc in it.
Interesting.
I will keep with the stuff that the Camshaft manufacturer recommends, I will believe that they know best......
