Goin mechanical roller lifters oiling ?s
polara64
New Member
Sacramento
I'm going mechanical roller I bought the indy 360-2 top end kit,heard alot of bad **** about the adjusters and pushrods,any way I'm going to be oiling the lifters threw the pushrod is there anything that has to be changed in the stock oiling system and what lifters are you guys running with the mechanical roller set up any input would help thanks
You're going to oil the rockers through the push rods? Who's lifters and rockers are you going to run?
LOL that took me a minute,.....you're going to push oil from the lifter body thru the hollow pushrod to the rocker arm. Not from the rocker arm down to the lifter.
I am using T&D rocker arms and Comp Cams 8043-16 roller lifters with my 360-2 Heads.
