Good deal bad deal? 318
Jonny H
PDX
1972 Dodge 318 (car) Short block Engine fresh rebuild complete assembly from oil pan to water pump, Enginetech pistons # p1516, 9 to1 comp .030 over, new lifters, fresh oil pump, *340 mech. fuel pump ( not the same as 318 fuel pump)
Hydraulic Cam specs
.050 timing btc-6, abc 30, bbc 43, atc-9. SAE timing btc 26 abc 72 bbc 75 atc 33
.050 Duration int 204, exh 214. SAE Duration int 278, exh 288
Lobe ctrs int108, exh 116. valve lift int.421 exh .444. Cam lift int. .281 exh .296 $200
I hop it was a good because I bought it
If you paid $200.00 you got a good deal, that cam is pretty mild and not sure how one would figure 9.0 compression without knowing what heads. what about the crank??
I would say any fresh rebuild short block for $200 is a great deal. Can't go wrong with that. It would cost you more then that just to buy the parts.
it has the steel truck crank ground and polished
I have some of the receipts, he paid $253 just for the block prep
That's a good cam for a 318. You'll get some non stock idle with those duration figures and that LSA in a teen. It won't be much, but it will be noticable. It will run better than it sounds.
