[WANTED] Gooseneck wanted
gsone1
Member
Rating - 0%
0   0   0
Need a stock factory gooseneck housing for thermostast one of the cast ones, I have a chrome one and it leaks like mad. Let me know if anyone has one I could buy ...Thanks gsone1
I'm pretty sure you can get one in cast iron from Oreillys etc... I think four seasons and maybe even Hayden make them. What engine and with or without A/C?
Is that the one that has the hose end that points towards the front about 20 degrees? I have one that has the angled end and I also have a straight one. Both cast iron.
You can take the chrome one and remove the chrome plating from the sealing surface with a wire wheel or a sanding block and they will seal up like a stock one.
