Got my heads back from porting...is this ok???
64physhy
Weatherford, TX
I just got my heads back from being ported today. I won't say who did it until I get to talk to them first. They are magnum heads, fully ported. They broke through where the valve cover bolt holes are. In one port, the hole is about 3/16" X 1/8", and the rest are pinholes with paper thin metal left. I don't know much about porting heads. I know definitely do not break into any of the water journals, which they did not. Is this normal, or should I be getting in someones a$$ over it? I'll try to get pics up later. Thanks, Dave
well...hopefully...the valve cover bolt will seal the intake port....or jb weld...
it has to be sealed.
Use studs for the valve cover and put some good thread sealer on them.
