gotter done
dartbob
Active Member
well i fininshed my magnuam head small block on fri. and ran it on the dyno. the little 360 pulled 410 ft.lbs. and 385 hp. that was uncorrected numbers. so im pretty happy with the 1850.00 i spent.
i'm a machinist and was able to use the equipment at my buddys engine shop. he helped me out alot and i got some stuff threw him.
stock bottom end, kb flattops, comps exstream 284 cam, magnuam heads with roller rockers ,rpm air gap,and holly 750, tti headers. torq curve was great best number at 4200 and hp at 5900 motor rev good all the way to 7000.
i did port match the heads and bleanded the bowls and five angle grind job.
