Actually its supposed to be de-mineralized water. Distilled is better than tap water, and under no conditions ever use well water!Make sure you use Distilled water and I find best deals on it in the drugstore chains, Walgreens & CVS.
Thats fine if you run a stock radiator. Can always mix it a tad stronger as well. Can go as much as 70%coolant with some brands.50/50 premix doesn't work anyway......
You can't get all the water out the block after flushing.
So you end up with something like 40/60 (antifreeze/water) when using premix.
I always look up the cooling system capacity to figure out how much full strength antifreeze to put in. Top it with water.
